What have people run at the track with and w/o the PP, completely stock? That'll give you your 1/4 mile time. I thought Insideline had tested our cars and ran like 13.8 s with the PP and 14.1 w/o it, but that's off the top of my head.
The differance is very slight and I doubt it make a 2 tenth improvement. In a modded car the taller gears would be the way to go. IMHO These things
are designed for low end power and the taller gears actually "load" the turbos
more. I wouldn't be surprised with all things being equal the higher gears win.
Another factor that needs to be considered is where each vehicle is in the powerband of it's gearing at the 60 ft mark, 1/8 mi and 1/4 mi.
Using a Pontiac G8 Gt as an example, many drag racers hold them in 3rd and let them bounce off the rev limiter rather than let them shift into 4th, as the shift costs a couple tenths. To keep car from hitting rev limiter, one has to either increase the rev limiter setting or increase tire diameter.
Another consideration that hasn't been discussed is weight of your wheels/tires. 20" wheels/tires are generally heavier by a few pounds each. That could bring performance between reg. SHO and PP SHO with 20"s, closer in times. With my Brick... I have shorter & lighter 18" tires/wheels. Have saved over 60 total lbs. My axle ratio is an effective 3.40 up from stock 3.16. Still, my mileage is not worse, likely because I have a 3+ inch lower Flex (only 63" tall) and a lower un-sprung weight.
I run .3 quicker than Livernois car, I have the PP, they don't. Dan attributes it to the gearing. Not sure if that helps
Darreli's Times "Brick Times"
Oct 1 -75 deg high humidity
60ft...........1.8639 1.956 .12
330ft..........5.2890 5.587 .3
1/8 ET........8.186 8.641 .45
1/8 MPH......85.20 80.54 4.7 mph
1000' ET......10.6941 11.285 .59
1000' MPH....98.25
1/4 ET.........12.788 13.522 .734
1/4 MPH.......110.12 100.74 9.38 mph
Quite a bit of difference!
And my reaction times were so slow... that a friend at TireRack claims he could have downed a chili cheese dog and a coke before I left the line!
(NOTE: I TRIED TO EDIT THIS TO SPACE IT PROPERLY BUT NOT POSSIBLE)
my question is: how much faster do u think these gears are than 2.77 in the quarter mile and 0-60?
Are these gears optional on cars delivered here in Canada? Any canucks out there who may know?
Seems they're part of a performance package in car delivered in the US but I don't see that option up here in Canada.
Thanks,
SG
