First IAC , I s there is a differance between the two, which design should I use or does it make any differance? Next do I need to use the spacer? the throttle body will be bypassed ( for heat that is) so should I still run coolant to the spacer or can I get rid of it all together.... The 3.0 unit is still bolted to manifold in this pic.
I running a 3.2 intake with egr blocked and a 3.0 harness /computer/ 3.2 injectors on a 3.0 bored to 3.2
However, I don't think that he is running a charcoal canister.
