jmpSHO
What is the benefit of installing 3.0 cams in a 3.2 ATX? If there is a benefit and I decide to do it, do I need to swap the heads too.
iirc, from what I've seen the only difference in dyno numbers (before and after) was above 5500 rpm.
nah you have it right. Just swap the cams that have the timing belt sprockets. Just make sure you get the timing right on the chain part of the deal, cuz that can easily get done wrong. Also do a valve adjustment. Everything can be found on ShoPhoenixProject.com
i did it to my 3.2 as far as a difference couldnt tell ya havent really driven her much :cry::cry:
