CAR93ATX
I had the car died when driving last Friday, as http://dwww.shoforum.com/ubb/ultimatebb.php?ubb=get_topic=03;f=17;t=009740#000000 Link here</a>.
Tonight, when I drove down a sharp hill, the speed is about 65MPH, I shift from "D" to "2" to prevent too fast and too hard break, had done that no problem with Crown Victoria. The car slow down to about 45PMH. Then check engine light on, I shifted back to "D", and add a little bit gas tried to back to 55MPH. The car died at that moment and had to move to left turn lane to prevent hit by car behind. Started right away immediately after stop> park > turn on the key.
Check the code. same as previous, 157, 332, 648.
Is code 648--4th gear ratio error can creat this problem? When I changed the tranny filter in last summer, I feeled the filter was not tie enough but did not think too much at that time. Could a loose and dropped filter in the pan create this problem too? (also, I decide to change the filter this weekend, just in case)
Any thought will be really appreciate.
