2nd Gen MTX and ATX share the same radiator?
bmxludwig
Sibley, IA
Title says it all, I just need to know if a radiator from a 94 MTX will fit a 93 ATX... Thanks!
clindahl
Raleigh, NC
Sort of. Many aftermarket radiators are the same, they have the transmission cooler in them, but just not used on the MTX. I don't know about the OEM radiator (I doubt it will work), but any aftermarket, check to make sure it has the cooler ports and your good to go :)
the4biddendonut
Hurry up meow.
Elk River MN
The MTX radiator is missing a mount that the ATX radiator shroud uses for support. It's a very similar radiator and could be rigged to work though.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
I know you can go the other way around. I have a radiator from an auto, plugged the holes for the tranny cooler, and it fit just fine. Not sure about MTX --> ATX tho.
