214 Code Questions
jayro
Auburn, In
Okay guys, at the track I noticed I would loose power for a second, the CEL would come on and then the car would start pulling just fine again. As the weekend progressed it started happening more and more. Pulled the codes and got a 214 (cylinder ID). This pointed to the cam sensor which was new last year. I went ahead an replaced it since I know they can be bad out of the box. This didn't solve the problem. Besides the sensor the only things I know that would throw this code would be the DIS,coil pack, bad ground or bad wiring to these things.....maybe a faulty ECU? I am looking to source these components to replace them, but is there anything else that I should be looking into? Thanks in advance for the help.
if its not the cam sensor, then it could be wiring to the cam sensor or the dis. for some reason, a sick dis can cause other codes to point you down a rabbit trail. of course, it could be a pcm as well.
