2015 SHO, When cold, weird squeal comes from engine. VIDEO Attached
SHOrod
Torrie Tuned
Cedar Rapids, IA
The noise is present without the brakes applied and doesn't change as the brakes are applied. It's constant in frequency and pitch, not dependent upon vehicle speed or engine speed. The reason I swapped out the ABS pump was because my ChassisEar suggested that the noise was loudest on the ABS pump.
-Rod
SHOrod
Torrie Tuned
Cedar Rapids, IA
So this week I started to hear a howling noise indicative of a failing PTU. I searched YouTube for videos on that process and low and behold, the first video I clicked on sounded very similar....
This guy took off more parts than should be necessary, and also took what seems to me to be a more challenging method of removing the right half shaft (releasing the lower control arm versus the spindle), but overall some good information here.
I'm hopeful after replacing the PTU my dolphin will go back out to sea too.
-Rod
SHOrod
Torrie Tuned
Cedar Rapids, IA
I finally tackled the PTU replacement last weekend and I'm happy to report that it appears to have taken care of the "happy dolphin" noise. Oddly the howling/rumbling is still present, but I'm kind of wondering if it's due to the tires since I really only notice it on the freshly re-paved road near my house. I need to spend more time trying to track that down.
On my Lincoln MKS I was afraid I might break the bolts that hold the catalytic converter to the turbo, so instead I opted to remove the exhaust flex pipes (where I did break a bolt). I quickly realized that the PTU would not come out through the available space. I'm really not even positive that it would have fit even if the catalytic converter were removed. So I removed the entire subframe and honestly, for as little time as that takes, it makes the job MUCH easier and opens up the entire area to reach many of the bolts. If I were to do it again (which I hope to never have to) I would drop the subframe before removing the passenger half shaft and PTU bolts.
One tidbit that I never did find in any of the videos I watched - the steering shaft is keyed at the steering rack so there's no need to mark the position before dropping the subframe. But you WILL need to keep the steering wheel from moving once it's disconnected from the rack to avoid damaging the clockspring. Oh, also the connectors for the electric power steering are a lot easier to access once the subframe is lowered a few inches.
After I made sure the new PTU bolted up correctly I opened my old PTU, which I drained and filled with Lightweight Shockproof fluid probably 10k miles ago. The fluid was still liquid, but it was very stinky and dark black. The fluid change was too late to save the PTU, and all the roller bearings for the middle shaft were gone, similar to what so many videos show. So many videos that it kind of makes me wonder if the bearings were ever actually installed to begin with. On mine the bearing race is still intact, but no rollers were to be found.
-Rod
SHOrod
Torrie Tuned
Cedar Rapids, IA
It's been a week of daily driving and so far no sign of the dolphin-like noise, so I'm comfortable saying the PTU was the source of that sound. Before replacing the PTU I'd hear the noise at least once per day. I still would swear the noise did not seem to be vehicle speed dependent, other than the vehicle had to be moving. But I am apparently wrong on that.
-Rod
SHOrod
Torrie Tuned
Cedar Rapids, IA
I'm sticking a fork in my noise. Almost 2 months later and there's been no sign of the "happy dolphin" noise so I'm confident that the PTU was the source. It wasn't much fun to replace, but it was worth the cost and time. I'm glad I replaced the PTU before it left me stranded.
-Rod
CDB3
Missouri
2015 Taurus SHO - Squealing from engine when cold (Less than 40 degrees). Only happens in the first few miles, and stops after a minute or two down the road. Chirp/Squeal has gotten slightly louder, and lasts for a significantly longer time than it did initially. Any ideas??? Video embedded below....
I have same noise and can't figure it out. New belt tensioner and belt. All new timing chain, water pump etc.
SHOrod
Torrie Tuned
Cedar Rapids, IA
Welcome to the forum! Have you read through all the comments on this post? My noise was nearly identical and was solved by replacing the PTU. A wireless ChassisEar helped to confirm the source of the noise.
-Rod
CDB3
Missouri
-Rod
Thanks for responding, i was afraid of that.
SHOrod
Torrie Tuned
Cedar Rapids, IA
You may want to start by changing the gear oil in the PTU. When draining (or at least attempting to drain depending on the consistency) if the oil is thick and had a noticeably metallic look, then your PTU is certainly on it's way out.
-Rod
CDB3
Missouri
-Rod
Thanks, i will just by new PTU and hopefully end this issue once and for all
SHOrod
Torrie Tuned
Cedar Rapids, IA
I don't think you'll regret it in the long run. Be sure you or the shop order the correct PTU for your SHO. The ones for the NA platform are not the same, and the "upgraded" Dorman unit with the heat shield also is not for the turbo vehicles. And then there are the "With performance package" and "Without performance package" variants.
-Rod
CDB3
Missouri
-Rod
Im definitely buying one with heat shield and fill plug
