2015 Headlight Problem
IowaSHO
Iowa
I have a 2015 SHO non PP. Last night I started the car, the drivers side headlight flickered, then went out. Neither low beam or high beam work on the drivers side. Passengers side works as it should. Has anyone else had this issue? I'm thinking it's the ballast, but would like some input before I go throwing parts at it. Thanks.
AlexS925
Metro Detroit Michigan
Not to sound ignorant but have you tried switching the working bulb with the driver’s side? Would be a quick and 0$ way of knowing if it’s a bigger issue
