2015 Daily Diver non PP Livernois question
321GO
Considering getting the Livernois tune and 3bar map only. Wondering if I could pass on the Tstat for now during the winter months?
Yes.
And it is highly recommended to run a higher grade fuel than the tune requires during this time. so if you have 93 gas, use 91 or lower tune.
marius883
Orlando, FL
I've been running their 91 stage 4plus for over a year now with no additional parts. I'll be putting in a new thermostat in the coming months, but it runs great as is.
RamAireTransAm
They dont offer the 4x tune on the 13Plus cars
DerricksSHO
Michigan
I am currently tuned by Livernois and think its a great Idea to be tuned by one of the best they work with you and I give their customer service a A... But be prepared to be detuned for winter save up and buy spring time... im on a 89 oct tune running 93 SHELL..... and they have a V8+ tune more boost for the 13 plus cars
StealBlueSho
NA
I highly recommend getting the tstat... These cars are heat monsters...It's not expensive and you can install yourself in only a few minutes.
Sent from my Nexus 6P using Tapatalk
marius883
Orlando, FL
After using my obd2 wifi dongle driving home yesterday, I agree. I need a new thermostat! Car was running around 190 and spiked up to 205 is this normal? Also I'm running livernois 91 stage 4 plus and I only saw 11-12psi of boost.
StealBlueSho
NA
Totally normal without a cooler Tstat.... Boost is on par with the LMS tunes.. their tunes are heavy on the spark advance and lighter on the boost.
marius883
Orlando, FL
Ok, good to know, was starting to think I had a boost leak :/
StealBlueSho
NA
You would need to log your wgdc, tip boost, tip boost DSD, and MAP boost... Those four will help assist with a boost leak analysis... Of course the best would be a boost leak test... Based on what your seeing I think your probably fine.
Schiv1010
