2013 Lower control arm replacement
postwick
Is it as straightforward as it seems, or are there gotchas I don't want to find out the hard way? Rear bushing on the front control arm is shot, entire assembly is cheap enough so I just want to replace the whole thing.
It looks like it's just a matter of removing the front bolt, disconnecting the ball joint from the knuckle, removing the LCA then reverse to install.
TiresPlus wants $185 labor to do both sides so that tells me it's not a big job.
I have access to a lift and any necessary tools including air tools. Any tips would be appreciated.
Yipeekayea
I just did this a couple of months ago. The hardest part is the front bolt the only way you can get to it is with a open ended wrench just make sure you PB blast the c*** out of it.Other than that it's a pretty simple piece of cake installation. I would never pay anybody to do it and I'm pretty lazy
