2010 to 2015 sho engine swap
shoblock
Cleveland and Naples
I see literally hundreds of these engines fully assembled every day but I never see any of the connections they are hooked up to in the vehicle. I’m having my own process of discovery installing in the Gearhead intercooler, spending literally hours tracing the hook ups and understanding their functions to the motor.
Shoblock
Scott Milligan
WI
I'm a huge ecoboost fan, I have a 3.5 installed in a 2010 mustang race car and my DD is a 2013 ecoboost supercrew. I stumbled across a 2010 sho 50k miles with a blown engine. It's a really good deal and I wanted to pick this up to play around with, I've always loved the 2010+ sho.
I've found a long block engine from a 2015 sho with only 2k miles. I would need to use my 2010 turbos and all accessories for the 2015 engine. I realize that I would need to upgrade to water-cooled oil cooler and I found a list of parts for that. Is there any other problems I would have with this swap? Any wiring issues? Are the intakes different? Transmissions? I can't find much online about the differences, looks like just the oil cooler.
Thanks in advance for any advice you guys can give me!
I just did 2.of these. Last was a 14 motor in a 10. Heres what I found. The cam.sensor connectors are different. I swapped them from old to new eng. The tone ring on 1 of the new engines was different than the 10 . This Is the ring under the flex plate that triggers crank sensor. So I took the old crank sensor and ring and mounted to new engine. The new engine had an electrical connector on the PVC valve mounted on rear Valve cover. The 10 wiring harness didnt have this so unused my old PVC valve. You could probably use the es design and cap the plug. That was it, they both run great. I also installed new turbos, the rear is a real bitch to work on in the car and a new one is $420. I would also change ptu fluid while out. Much easier. 5e911bcd11274848bc1dfdfa794cf874
Sent from my SM-G965U using Tapatalk
Wonder if the pcv valve is heated on the 14, or there is some other function for the connection.
bpd1151
Lurking Around
SHOcago 'Burbs
I think the 2010's were/are the only one's that have this Manu.
There was a design change from what I recall in 2011.
Kingsped
I hope this doesn't sound stupid or something but did you have to swap the heads from the older engine to the newer one?
Im not sure if I missed that part or not but I'm about to start the same project in a few days.
Does anyone that has completed this swap have any advice or suggestions that might help?
Thanks in advance for your time and help..
RandR10
Heads don't need to be changed. Only thing that isn't compatible is the plastic valve covers from the later engines don't work on the early heads because they lack one of the bosses for the extra screw on the top of the front head. I think the rear head is identical. This won't be an issue for you because you're going from an early engine to a later one (correct?), and the aluminum valve covers from your current engine will work on the newer heads. Read my post from April 8, 2017. Should have most of the info you need there. If not, everything else is in this thread somewhere.
Kingsped
Yes I'm looking to replace the engine in my 2010 with a newer engine from a 2013-2015 or possibly newer if it will work.
I am looking at a 2015 explorer EcoBoost engine with very very low mileage and it's under $1,300.
I have low compression in 1 cylinder at like 80psi wet or dry.
All the others are perfect.
Thanks for your help and advice I will certainly check out your post on the subject..
If you can think of something that might help me get it done smoothly I would appreciate it truly.
I am gonna do the work in my garage with no lift.
I have already pulled the engine out previously so I am very comfortable with it..
Scott Milligan
WI
No head swap, just the sensors on the head (different plugs), the crank trigger wheel (tone ring) and crank sensor.
Kingsped
Will any 2013-2015 3.5l EcoBoost engine fit in my 2010 SHO
Ive been reading that they might have 2 different types of cam gears or something.
I might not be saying it right or something but ive been reading about some having a different heads,cam's or something.
Im wanting to just switch the sensors and go.
I can't verify solid answer but I can't afford to get stuck with one i can't use.
My only source of income is Disability at this time due a work related accident so money is very very tight.
Thanks in advance
Any transverse engine, yes. Not an F150 or Expedition engine, but Explorer, Flex, Taurus, MKT, these should work fine, there will be minor differences if you go non-Taurus, in addition to the ones already noted, possibly due to police vs non-police service but not sure.
Kingsped
Thanks for evereveryone's help. .
I truly appreciate it.
I can finally feel confident about moving forward with repairs to my SHO it's been almost 1 year without it.
I was dreading the fact of putting a used 2010-2012 with tons of mileage and a unknown history of maintaince.
The newer Engines are significantly cheaper with way less mileage..
I will update when this is done and might actually take a video of the entire process from start to finish..
The jury is still out on how well the redesigned timing chains hold up compared to those for the single sprocket. Personally I do not think there is a gain of magical immunity from failure. The literature of course goes ga ga when theoretically performance achievements are made :) Resist temptation to overextend oil change and coolant change intervals - this will be your best ally in the future.
Jeff2017
If you want your timing chain components to last, change your oil frequently. At least every 5k using synthetic oil and a MC oil filter.​
JBKENNE4
THOMASTON ALABAMA
man great info, my son has a 2010 sho and he bought a 2015 police interceptor service engine and I was going to get him the atp turbo upgrade. but I am uncertain what the rods and pistons can handle this is info on engine . can anyone help me with this or point me in the right direction. i want to do this right and hopefully surprise the local strip,, thanks20200324 011908
Check out the other threads for rebuilds and recent failures. At least 2 projects going on now. Should be some pics in those as well. Instead of me pretending I'll ask for clarification. What is a service engine? I understand these are service vehicles. was this a replacement unit on a shelf or removed from a high mileage/hours vehicle?
shoblock
Glad you asked! A service engine is a huge, expensive part of an engine assembly plant. There are as many reasons that a new engine becomes a service engine, or, is 'sent for service'. Example: 10 engines were found to have suspect soft crankshafts. Rather than risk a warranty issue, all ten are sent for service, which would involve saving all of the components except the crankshafts at an authorized third party facility. The plant doesn't have the floor space or people to do the teardown/reassemble work. The third party would save all the good components and assemble a new engine. There are as many reasons an engine becomes 'service' as there are engine components. Sometimes parts on the newly built engine become obsolete due to model year revisions and all of the suspect, perfectly good engines go to 'service'.
Bottom line is you get a new engine, though it did not necessarily go 'first time through' assembly. There is a very low risk for failure, hence, the warranty that comes with each new service engine.
I would not hesitate to put one in my car.
Shoblock
