2010 Engine Replacement
Trifon T
SD
Got a 2010 SHO with a blown motor. Need to replace and was wondering if I can install the 2013-16 engine or if I am stuck with 2010-2012?
You can. There are some parts to swap over if I remember correctly. It's archived in other posts if you try the search function I think you can get info you're looking for.
Search for engine swap or something like that. You can narrow the field by selecting the GenIV section under the search terms in a drop down box so you only get results from the newer tt cars and not the old cars.
