1996 SHO 143k Miles, was a 1 owner car that I bought with 136k on it, great condition inside and out, ran like a dream! then, there I was, in the taco bell drive thru and it was snowing (this actually happened this spring) and my car got a really rough Idle and was unable to start back up and I had to be towed home...
I thought it was a cam sprocket failure for sure, and maybe still? but I started it up today, while it is really loud and has a rough idle which requires a little bit of gas to keep from dying, it runs... (sounds almost like it has an intense exhaust leak right at the catalytic converter... now my question to you all...
Can your SHO Function even after cam sprocket failure? As I am looking everywhere for answers it seems to me like they say since it is an interference engine that it would be toast... well I can still get this guy to hit about 4,000rpms (didn't go too ******* this barely running beast or could have probably gotten higher) but the revs kind of lagged and it stayed at about 3k for a few seconds before hitting a wall and going back to barely running...
would you say that in theory that 8 of 32 (1 of 4 cams) is unfunctional and banging around while the other 6 cylinders are still running strong? or does it not work like that? I am able to put my car in reverse and drive and was able to drive it in my driveway but my gas light is on and that is some really old gas.. I am thinking about waiting until payday and getting some fresh gas in there and seeing if it is at all drive-able on the road/see how it actually acts
If anyone has any suggestions of what it could be, or why it would sound so loud right outside of the exhaust manifold, or if you know for sure it is the sprocket or whatever just post and let me know if you are familiar, I was 99.8% it was the sprockets when I couldn't get it restarted in the winter, but now that summer is here and it sat for awhile it appears to be at least runable...
thoughts?
Thank you
thoughts?
Thank you
well, if nothing else, i'll have some more experience taking apart an engine.
