1995 MTX shifter issue
joeinaz
AZ
I have a 1995 MTX SHO with an issue with the shifter. While I am able to shift into all gears my shifter rotates in place making the shift action difficult. The whole stick can rotate 360 degrees. Some questions:
  1. Has anyone else had this problem?
  2. Is there a recommended repair or solution?
  3. The repair manual shows the shift assembly as a single part but I cannot find it anywhere; is there an aftermarket alternative?
Thanks in advance for any help...
BaySHO Performance
SF South Bay
My '90 has the same problem. The ball at the bottom of the gear lever is broken. Doesn't really affect shifting that much, except I have to watch which gear I'm selecting. SHO Source is working on a fix.
jzero391
