-DVP-
NaNaaNaNAAAA!!!
1991 Plus
Green/Mocha
3.0-Stock
CM1
17lb Flywheel
K&N drop in
Magnaflow Y pipe with Wagner stock replacement catback
Rod shifter
ASFB
SHONUT Extreme MMs
11.6" front (94/95 knuckles)
HAWK HPS front pads
Gen II rear knuckles w/ stock brakes
Slicers
Gen II wheel
Gen II Full leather
EATC relocated
Hard button EATC
Tint 35%/5%
Stock grill
*** UPDATE ***
Car was rear ended back in December. I have since taken all the parts I wanted to keep and returned it to mostly stock. The damage is fixable, I just dont want to do it. It runs and drives just like it did minus my suspension. I am STILL using it as my daily. Here are the current pictures. (Will have all center caps and does have grill emblem)
-A/C is cold, heat is hot. Could use a 60k. Around 185xxx. Paint is about 3-4 years old. Has never given me a problem. Has been my DD since June of 2009. I drive it anywhere and everywhere. Dogleg on pass side needs repaired, but IS FIXABLE. Paint isnt perfect but it does clean up nice. Will come with slicers. Want a Gen III so the Plus has to go...
ALSO I have a book of receipts from the original owner. All the work that was done on the car before St Louis SHO got it was done at the same dealer. anything that is not in that book was done by St Louis SHO. After the original owners mechanic at the dealer was not longer there he went to St Louis SHO for everything. There was never some ratard working on this car.
WHAT IS CAN/DID LOOK LIKE
$1000
Green/Mocha
3.0-Stock
CM1
17lb Flywheel
K&N drop in
Rod shifter
ASFB
SHONUT Extreme MMs
HAWK HPS front pads
Slicers
Gen II wheel
Gen II Full leather
EATC relocated
Hard button EATC
Tint 35%/5%
Stock grill
*** UPDATE ***
$1000
