116, 157,211, 542 ???
Petersho1
IL
I ran KOEO test, first part pass 111 then second continuous memory shows this 116-( ECT I replaced this one 6 weeks ago) 157- do I need new MAF??, 211-PIP no idea, 542- fuel pump. I dont know what to think. I had some starting problems lately. I heard FP all time. I thought it's CPS (replaced two months ago)
Have any ideas, Please HELP!
Thanks guys!
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Have you reset the codes since the manifold ground issue? That would set the 211.
The 157 code means you should at least clean your MAF, and if that doesn't alleviate the problem replacement will be necessary.
542 don't worry about.
116 - Did you run the test with the car completely warmed up?
Petersho1
IL
"116 - Did you run the test with the car completely warmed up? "
- was warm, maybe not that hot as should be. ECT is new right now so I'm not worry about this
"The 157 code means you should at least clean your MAF, and if that doesn't alleviate the problem replacement will be necessary."
-Yeah will try to clean up for sure
"Have you reset the codes since the manifold ground issue? That would set the 211."
- I don't know anything about ground issue. I'll take a look on all grounds in my car.
After all I'll reset the codes and we will see what happens.
Thanks!
