ImpressiveJust Hit 300k miles in my 2010 SHO yesterday.
Very nice. I'm at 193k and will probably have it for quite awhile. As far as I know, I got it at 100k , and only timing chains and wp had been done.No performance mods, I've done timing chains (twice, and it needs them again), both turbos once and the front turbo 2 more times (1 was a bad ford rebuild, then the Dorman I replaced it with started leaking almost immediately), Fuel injectors, coils, Transmission was rebuilt around 250k, almost the entire suspension has been replaced, and then the normal wear items (brakes, tires, plugs, etc). I think that pretty much sums it up.
Definitely not a 'trouble free' vehicle. I have not changed the PTU, and it is not in the maintenance records I got with the car when I bought it. I have tried to change the PTU oil out regularly, about every 30k or so using Red Line Lightweight Shockproof. Same with the rear diff. I did notice the PTU seems to be leaking now though.Tremendous number!
Lot's of maintenance too but are you still on the OEM PTU?
No, all stock performance wise. I did do the VTA mod and noise maker delete, but not tuned.@Shadow351 by any chance are you tuned?
Wow! My 2011 is at 193k, hopefully I'll hit that number too.Just Hit 300k miles in my 2010 SHO yesterday.
