Thank you kryptto. Heading over.welcome, head down to the gen 1/2 threads and repost.
Welcome! post some pics
Try THIS fix for the rear windows...worked for me!Just some common problems on it. Stuck rear windows stuck sunroof.
Gotta let that summer breeze in.looks good and the sunroof is up
Hello, thank you. I ended up replacing the window motor. Works like a charm now!Try THIS fix for the rear windows...worked for me!
3 windows not working
My '99 SHO has 3 windows that do not operate. Driver window is fine. Passenger window is very, very slow, only moves about 0.5" then stops. Both rear door windows don't even move. When I try to use the window switch in both rear doors, I can see the dome light dim as if there is current draw...shoforum.com
