Post pics of your lowered ride!
elarm1
Maryland Native
Woodbridge, Va
Everything I drive has to be lowered on performance springs, not just for the look but for the performance aspect as well. As you all know I just got my 92 MTX and I wanna see what they look like lowered! Please include your setup as well. Thanks:wave:
SinisterSHO
Rust free
630, IL
93 w/ 18s has coilovers
92 w/ slicers is on tokicko/eibach
Shoaz
Studly dood
Scottsdale, AZ
This doesn't really show the ride height that well, but this is the Pumpkin after reworking the front struts (shortened 1") and putting 8" (instead of 10") springs in the rear.
Pk new susp
The tires are 245/45-16, so the tires are not as big as they may look.
A good way to realistically compare ride height is to measure from the center of the wheel hub (or wheel center cap) vertically to the bottom of the fender lip in the wheel arch. Otherwise it can be really hard to tell visually whether two cars are higher or lower than each other.
I wouldn't drive the Pumpkin on the street because I'd be getting the front fascia hung up on road apples and insects, but it does look like some of you may have comparable or lower front ride height. The Pumpkin has a bit of rake to it, i.e., the rear is a little higher than the front with respect to the height of the floor pan above the ground.
krednjen
Kit car/90 SHO Derek SA TX
San Antonio TX
The story of my life. I just dont fit in anywhere.:cry:
PS: That's not me in the pic.
matasho
bigshotsho93
Beloit Wisconsin
intrax and konis with one coil cut off. and the strut lowered in the knuckle all four corners.
100 1335
Mikescarblue027
shootinirons
