camweld option
Mels
SHOVELHEAD
Brookfield CT
Hey fellas.
I'm looking at a (customer-owned) pristine 99 with less than 10k mi that has been stored for the past 5 years in the kind of climate-controlled garage that makes you want to just roll your eyes back in their sockets and enjoy a smoke afterward.
My question is this, being a Gen 1 guy, would this be an effective alternative to what has become accepted as the "norm" for preventing the cam gears from spinning on the shafts?
Cam Weld Alternative
kikkinasphalt
Wrrrrrrrr
Missouri
Hey fellas.
no
for all things sacred. please do not.
bacernate
97 MONEY PIT
Denver, Colorado
Didn't they used to sell that crap in a plastic egg?
You can use it to take pictures from newspaper but for the love of god not a cam weld!
SHO1
Coke Is It!
The State Of Hockey
As long as we know a real weld works I wouldn't try it. Pretty much the whole cost involved in doing a cam weld is in the labor of taking everything apart and putting back together. If doing yourself, still the same amount of labor either way. Once you're in there, I don't think the actual weld would cost anymore than the putty. I Wouldn't chance it.
Mels
SHOVELHEAD
Brookfield CT
What. I'm dead serious, man.
In his promo, Mr. Mays even says that this is a good alternative for automotive repair AND reduces my cost.
A buddy of mine says they've been using it on nuclear aircraft carriers for years with great success.
Besides, even if it ends up not working as good as an actual weld what's the worst that could happen?
jpSHO
Massachusetts
I thought you were joking until I just read your last post. If you're going to go through all the trouble to get at the cams you might as wll make them as strong as possible by welded them not using silly putty. Ford recommends some type of loctite, what a joke that is. Ford won't acknowledge a problem with the cams but they will devise a procedure to make them last longer.Engine - In Vehicle Camshaft Loctite(R) Service
Article No.
03-14-1
07/21/03
ENGINE - 3.4L SHO - IN VEHICLE LOCTITE SERVICE
PROCEDURE FOR CAMSHAFT TUBE AND GEAR
FORD:
1996-1999 TAURUS SHO
ISSUE
Some owners of V8 Taurus SHO vehicles may be making inappropriate or unnecessary modifications to increase the life of the camshafts. Camshaft failures are uncommon, even at high mileage. However, for those owners wishing to do so, this article provides an appropriate procedure that may extend the life of the camshafts.
ACTION
Adding Loctite 294 to the camshafts may extend the life of the bond between the camshaft gear and the tube. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
Adding Loctite 294 to the camshafts may extend the life of the bond between the camshaft gear and the tube. This procedure is appropriate for engines not experiencing upper engine valve train noise. If such noise is present, replacement of a camshaft may be required.
