I searched, but cannot find the answer to this one... (most of these threads seem to have been lost in the crash...)
I have a good 92 3.0/mtx on a subframe that I plan to put into a 95 atx that threw a rod. I also have a 93 mtx car (also w/ bad engine) for parts, so I can harvest anything I need. I would like to use the 93 mtx pcm, and I have some wiring questions.
1. can I just plug in the mtx pcm and use the 3.0 engine wiring harness, or are there other wiring changes I need to make in the engine compartment?
2. how do I wire the clutch interlock? do I jumper the neutral switch connector on the console where it used to plug into the atx trans selector, or is it different?
3. any other wiring changes I need to make?
Thanks in advance.
Thanks in advance.
