Which rear endlinks are best?
1993MTXSHO
Its a Taurus...
Jersey
If you go all the way to the bottom of
http://www.rcmautomotive.com/id22.html
you will see the 2 different endlink designs. I want the best possible suspension I can have, less coilovers (even though I have a set) because I decided I am not putting them on my DD. Is there a difference in the sleeve design vs. the solid shaft design? Also what is the difference between TPR and Poly bushings, is TPR more solid?
1993MTXSHO
Its a Taurus...
Jersey
I thought you were getting out of the SHO game????
Read page... 5? maybe it was 4 of my parts ad, but it was a joke. I don't think I will ever be able to cure my sickness. I'll get some pics of of my 3 green pieces of crap tomorrow or something just for the **** of it:rofl: I have been thinking of getting down to one sho though for sure. I don't think I will sell my 93 though, my first sho has to stay forever:salute:
Storm-Chaser
Shit Louis
Search
. . . . discussed just last month . . . . Sway Bar End Link Recommendations
As to "recommendations", I beg to differ.
Adjustable endlinks may be required if the car has been lowered.
Outside of "looks" or the desire for TPR bushings, a rear endlink is a rear endlink. There's no point in wasting money on a more expensive item which is functionally no better than others. Many here (including myself) use the AutoZone Duralast SL114HD rear heavy duty swaybar endlink kits - they're $10.99 ea with a LLT (limited lifetime) warranty. An entire set is $21.98 and you'll likely be able to have them today.
Read my review/comments in the above thread about rear endlinks.
Adjustable is the best.
Next best option would be these: Endlinks that we sell
1993MTXSHO
Its a Taurus...
Jersey
not for 375 dollars:rofl: I want best but not that good when I can get pretty much the same for 25 bucks. I am just running stock eibachs in the rear so I won't need them to be adjustable.
LOUDSHO92
Rancho Cucamonga, CA
I thought you were going to be getting Ground Control? Thats why I suggested the adjustable.
I do agree though adjustable are best for when extremely lowered or you are into tracking a lot.
We are working on some other options though.
ManySHOs
South Jersey
FWIW, I just bought the Moog TPR's from Russ at RCM. I installed them today. They are exactly like the Addcoo 007's w/poly that I sawzalled off and like the Duralasts with rubber bushings that I bought from AZ and will return. If the car wasn't going to be down as long as it has been, I would have installed the Duralasts and been done with it. I decided to order the TPR to try something different.
I considered the powergrids that SHOsource offers but I'm not going that route unless I have my car cornerweighted and find out that they are a necessity.
Ian
1993MTXSHO
Its a Taurus...
Jersey
I was going to go ground control, I do have the kit (its brand spanking new), but I decided after reading up that it't not a good idea on a DD, so I am going to stick with my Eibach/Koni's:thumb:
shobroooo
