Very interesting build. What size is your downpipe?
What size is the rest of your exhaust? And what size is your uppipe? You mention wanting a larger dp so the turbo spools better, but I can assure you, a 3" is MORE than sufficient for the t3/4 you are running. (I am running a 2.5" DP, on a sizeably larger turbo, and the car breathes well all the way to redline) And a BB turbo of that size should spool very quickly. Do you have the specs on the turbo? And can you better describe the spooling characteristics, and how much boost you are making at what rpm?
Can you put up more pics and and more information on your build. And try and spell correctly, it was hard to read your post with the numerous errors in it. I am looking forward to hearing more on it.
hope yuare not from the brithish academy of lenguage pal i bet you my english is a lot beter than your spanish, you remember me my english profesor.
there go the pics. the car has no maf, just a map sensor,
and a huge fmic.
El hombre apesadumbrado, como me dije nunca significó ofenderle. Hombre hermoso de turbo SHO, lo amo. ¿Usted lo funcionó nunca en la milla cuarta? ¿Si tan cómo hace? También qué alzan llano es usted que funciona. I' m que construye uno y que va a funcionar 12 PSI normalmente y el overboast él en 15psi. Una más cosa, cómo usted consiguió el coche en Puerto Rico, ellos didn' ¿t los exporta a allí hizo ellos? Apesadumbrado sobre el comentario del deletreo otra vez, I didn' t sabe que usted era de un diverso país. Espero que poder todavía ser amigos. Gracias otra vez. Y una más cosa, qué un poco computadora es usted que funciona para la gerencia de combustible Gracias, Su amigo Johnathon picosegundo. Espero que usted pueda por lo menos leer mi deletreo como I' m no bueno con español.
How did you type all of that while taped to a pole?
I wish that I was bilingual. I was going to take some Spanish classes this summer too...
Ian
the car pased emmisions with honors and its very simple to program. i never run the 1/4 mile i think shos arent good for that and mtx are hard to come.
