por fin el ticosho
Toolman
Boost it!
Grand Lake, Oklahoma, USA
What size is the rest of your exhaust? And what size is your uppipe? You mention wanting a larger dp so the turbo spools better, but I can assure you, a 3" is MORE than sufficient for the t3/4 you are running. (I am running a 2.5" DP, on a sizeably larger turbo, and the car breathes well all the way to redline) And a BB turbo of that size should spool very quickly. Do you have the specs on the turbo? And can you better describe the spooling characteristics, and how much boost you are making at what rpm?
Brett
SHOs before HOs
Minnesnowta
Nice build! It looks pretty well done!
Like a kid in a candy store... :p
adidas_kn
LOWSHO
Houston Texas
Hmmm daddy likey. What are you using to cool the car down? I can only assume a pushing fan since there is no room for a puller setup. Is that a single core radiator(stock) or the uprated double core?
fogsho
san jose costa rica
yes you are right its a pusher fan, and a triple core copper radiator made here. also it has a quaife:thumb: that i bought from sho shop several years ago.
ManySHOs
South Jersey
Can you put up more pics and and more information on your build. And try and spell correctly, it was hard to read your post with the numerous errors in it. I am looking forward to hearing more on it.
In that case, your signature is not grammatically correct. It should be "beaten", not "beat". :)
Ian
1995SHO9
FLEES ARE COMIN
Carlisle PA
hope yuare not from the brithish academy of lenguage pal i bet you my english is a lot beter than your spanish, you remember me my english profesor.
there go the pics. the car has no maf, just a map sensor,
and a huge fmic.
El hombre apesadumbrado, como me dije nunca significó ofenderle. Hombre hermoso de turbo SHO, lo amo. ¿Usted lo funcionó nunca en la milla cuarta? ¿Si tan cómo hace? También qué alzan llano es usted que funciona. I' m que construye uno y que va a funcionar 12 PSI normalmente y el overboast él en 15psi. Una más cosa, cómo usted consiguió el coche en Puerto Rico, ellos didn' ¿t los exporta a allí hizo ellos? Apesadumbrado sobre el comentario del deletreo otra vez, I didn' t sabe que usted era de un diverso país. Espero que poder todavía ser amigos. Gracias otra vez. Y una más cosa, qué un poco computadora es usted que funciona para la gerencia de combustible Gracias, Su amigo Johnathon picosegundo. Espero que usted pueda por lo menos leer mi deletreo como I' m no bueno con español.
sho2see
sho2see
Baltimore, MD
:huh:
ManySHOs
South Jersey
How did you type all of that while taped to a pole? :)
I wish that I was bilingual. I was going to take some Spanish classes this summer too...
Ian
1995SHO9
FLEES ARE COMIN
Carlisle PA
Ian
Um cause I'm cool like that?
And were you there that night, I don't recall who you are.
jthod
Mr. Goodwrench
Lincoln, Nebraska
3 years here, and I only use it.....never. Except when our regular Guatemalan painters Johnny and Anselmo come in!!! These guys are great! Hardly a word of English, but damn nice.
fogsho
san jose costa rica
dont be apesadumbrado, this forum is about people that loves cars and the sho. im using an simple digital sistems fuel injection that works on a map sensor and a magnet put on the crank pulley it is not secuential but i does not need to, the car pased emmisions with honors and its very simple to program. i never run the 1/4 mile i think shos arent good for that and mtx are hard to come. if i take the sho to the strip ill post you results, now im working in the suspenstion bump steer problem, what i want is a nice audi killer. anybody know what is the a winnning noise tha the motor has?. which is the best turbo for the sho?
hawkeye18
Sorta cares
Norfolk, VA
Well the man may not speak perfect english (who does, anyway?), but he is wise beyond his years in SHOdom. How haven't we known this guy forever? This guy gives Tom a run for his money!
