LJRuddy
Pop lock n drop
So about 10,000 miles ago, my rear pads went south and being that the temp was hovering around 0 degrees, I put them off until they destroyed the rotor. I bought a new set of pads/rotors and installed them. The slide pins seemed to have plenty of grease on them so i never put any on. For some reason, my passenger rear caliper was sticking pretty badly. On a slight hill, the car would not want to roll backwards and every trip I took no matter how long or short, the right rear wheel was twice as hot at the front wheels. My passenger rear wheel always smelled of burnt pads. Long story short, those pads made it about 2,000 miles before they needed to be changed. This time, I packed the slide pins full of grease and installed the brake system together properly. However, after bleeding the system, the wheel could be turned by hand but the rotor was still grinding against the brake pads. The wheel would not spin for long as the pads seemed to be stuck against the rotor.
I have ruled out the E-brake, bad brake fluid, and stuck slide pins. So I guess my next problem could be a collapsed hose. I have never had this issue so I am not in the know about this problem. Can you tell by looking at a collapsed hose that it is indeed in need of repair? I tried to squeeze the brake hose by hand and there were no soft spots that I could feel. The car does not pull to the left or right under hard braking.
I do have a set of Earl's stainless brake lines that I forgot I had (should have installed them today) so if it is indeed a collapsed hose, its no big deal. I just want to be 100% certain that I will solve my problem.:wave:
On a side note, I cleaned up all of my ABS contacts and I finally got rid of that pesky ABS light that came on at 18 mph. It feels good to have working ABS now. And after using it on a few gravel roads and rebleeding the system, that brake pedal has never felt so firm.
