HotRodKid
mmmmm ... turbo
hey way the ecu displays knock.... has anyone done research in the SHO community to see how the ecu deals with knock.
reason i ask. ive seen naturally aspirated ecus only indicate knock once audible knock is detected... ie you hear knock in the car (ie bad) and then the ecu pulls some timing and indicates knock.
all turbo ecus that i know of, are much more sensitive to know and indicate knock and pull timing far before you ever hear it with your ears.
you could make a detonation can/earmuffs setups and listen closely and watch tweecer to see if you are getting indicated knock. if you dont
hear barely anything in the earmuffs or the slightest tick and tweecer indicates knockm then the system is working to a safe level.
i dont know about all ecus but i know that turbo chrysler ecus have additional circuitry to "store" the peak of the knock signal using a capacitor after every ignition pulse so that the ecu can easily read it without having to deal with the small window of time when the knock occurs and then it clears the capacitor to ground before the next ignition cycle. here is a diagram.
http://www.squirrelpf.com/bucar/ecu%...ation_diag.gif
the other think you need to know is if the knock sensor has a flat frequency response and the filtering is done in the ecu or if the sensor is tuned to a specific frequency. my sensor is sensitive to noises in the 6000-6300hz range. i dont know what sho sensors are or if the ECU does filtering.
so what say the tuning gods ? lol
how sensitive is the SHO knock sensor and such ?
