This is my personal 94 mtx with issues. Car has a 3.2 with shoshop stage 2 cams. Car has spark and fuel but does not fire up. I have tested all sensors multiple times and all grounds are present. Every wire has been tested out in the entire harness to make sure nothing went bad. Timing has been redone probably 5 times today. This car has not been fired up since the heads with cams have been installed- they were in a working car and I removed them today from my engine to make sure they did not have any bent valves from improper timing since I was told the engine is now interference with the cams.
Is there any special ways this needs to be timed to get it to fire up? I have called everyone I know who may know the answer but they are as perplexed as I am. A couple times I have had a backfire out the intake which leads me to believe the timing is off but everytime I check it is correct. I even pulled out a spare set of heads to check the cams and they are installed correctly in both heads.
Again, all sensors are working. All grounds are present. I'm trying to get it running for the FSHOC meet this Friday. The 3.2 is running all the correct 3.0 pieces as well.
). And yes, the wires are *supposed* to go on bass ackwards.
