What are some common problems with the Ford Taurus SHO?
Keith M
RI
Many of the esoteric parts (and even some common ones) are now discontinued, many more will be...it helps to get cozy with your local salvage yard people.
I'd also agree with the notion that if you don't work on it yourself, you'd better have an ace mechanic standing by...
expy916
sacramento
Are the plugs a pain in the ass to replace? Are parts hard to find for the SHO?
The answer to your first question: Yes, if you dont have experience with the SHO motor.
The answer to your second question: **** yeah
jthod
Mr. Goodwrench
Lincoln, Nebraska
If you are going to do the plugs and wires, It helps to have the intake off. It's not terribly hard to take off, but I wouldn't want to do it any more time than I have to.
If you are going to do the Plugs and Wire, I suggest you just go ahead and do the whole top 60k. CLICK HEREAnd while you have intake off, clean the **** out of it.
frosho
WOLFMAN
Tyngsboro, MA
Some parts are obsolete and/or hard to find, yes, but it's not that bad. I've gotten the vast majority of parts I've needed for my car from Autozone. The majority of those were available off the shelf too, no ordering necessary. Then there's Rockauto, RCM, and SHO Source on the internet to name a few.
And like Keith M said, knowing the boneyards in your area will help too.
TYSHO
Earth
It would be wise to do so, regardless of miles and having no documentation. If you're looking to run the car to the ground then dump it, you don't "need" to.
TYSHO
Earth
1. No, you just pull the spark plug wires out and get to them with a rachet, long extension, and proper socket. This can be done on the back side as well, don't be discouraged. If you have problems with the back side, middle plug, just slide the black cylinder looking piece out of its brace and you'll be set. Shouldn't take you more than 30 minutes to do the whole job.
2. Not really, it's just people complain about the price of obsolete parts still available that aftermarket companies have not showed interested in producing. Here's a list of some parts I know of and where they sit which people believe are not available: New 3.0L Heads [sold a set to a member here, actually], New Pistons, New Bearings, New Camshafts, New COMPLETE Gasket Kits, New Blocking Rings, Output/Input Shafts, Tranny Bearings, Tranny Case Halfs, Shifter Cables [89-91], and the list can go on. These aren't you're typical parts needed to keep a SHO running, those kind of parts can be found in any auto store and are priced average to any used car [sometimes cheaper]. Also, the SHO shares A LOT of parts that are common with the regular Taurus. Don't let ignorance fool you...
TYSHO
Earth
Wait, did you just say you know where you can get all those parts new?
Been knowing, I even tried to give deals to some SHO vendors to offer new V8 short blocks for $200 each but they were only interested in their benefit. You guys think all high of vendors when the only true one trying to help keep these cars on the road is SHONUT Performance. Food for thought...
jruss1601
Southwestern PA
I heard from a few people that if you ever sell your SHO you'll miss it. I know thats true. The car locks all the doors when you put it in drive and releases the e-brake if its on. I love the climate control. Power seats that move every way and hug you. Automatic headlights. Premium Speakers from the factory (in 92). The looks and comments the car gets. I think the 92's even come with coin holders and a cup holder. I know i cant get all that in newer cars without paying big bucks.
Once i got my waterpump and timing belt changed i've been getting mileage around 25 and thats a mix of 70 mile trips on highway and less than a mile trips in the city. I have an automatic. A problem i have is that the check engine light keeps coming on and going off. I just ignore it now but its bright at night. I'm also having trouble with my sunroof not opening. Little things that aren't of much importance.
As for the sale, i'd say go for it but expect to pay big bucks to get anything fixed if it ever needs it. I was mechanically inclined until i bought this car. Its like a whole nother world
frosho
WOLFMAN
Tyngsboro, MA
Your check engine light is flashing because the computer detected a problem and stored a trouble code. To say that part of the onboard diagnostic system that's only doing its job by indicating a problem is one of the "little things that aren't of much importance" is pretty ignorant. Get a paperclip, figure out what's causing it to flash, and get it fixed. No more light to **** you off at night.
jruss1601
Southwestern PA
I've heard other people say that a check engine light going on and off is a common SHO problem. And i had bought a code reader and checked it. It said oxygen sensor, fixed it, still says its a problem. Also something about a transmission clutch sensor. I have an automatic. The car is running fine. I'll make my own thread if this is something you really want to talk about. How about you solve my problem of why my sunroof wont open too. I made a thread about that, where were you then?
I just dont like to start tearing my car apart or start new jobs on it if everything is going just fine. I dont have a garage, all the tools, or much time to tear into this car. If you really want to solve my problem, i'll make a thread for it or you could just pm me
frosho
WOLFMAN
Tyngsboro, MA
It is common for a SHO, as well as many many other 13+ year old cars.
Did you remember to clear the codes after checking them? And an o2 sensor code can be caused by a number of things, not just the sensors themselves.
I dunno, probably reading threads I could contribute to lol. I don't have a sunroof nor have I worked on one, so I generally ignore threads about them.
Sorry if I came off as an ass. Not trying to attack you. Just trying to say that if your CEL is flashing, things are not necessarily going just fine. Something somewhere is causing it to flash. Also, I'd be happy to share any insight I may have with regards to your probs. That is, after all, part of the reason I frequent the forum. :thumb:
thecrew2999
3.2 MTX SHO
Harrisburg/WilliamsportPA
to make it all simple just do maintence.. look around for FULL maintence not just upper 60k or just lower 60k and make sure you change the rod bearings. after that with everything in place you will be good.
no reason you cant hit 430k miles like i seen one of the members here got.
Siren
Petrolhead
California
My gf is looking at a 92 Ford Taurus SHO with 102,000 miles, fully loaded with the 5 speed. How reliable are these cars? Are there any common problems with these cars? I know it has the Yamaha v6 engine, is it a good engine? Any known problems with the yamaha v6 engine? Any common electrical problems? Anything else to look for besides the basic stuff?
I'm not going to bother reading the rest of the thread before I reply, so if there are any duplicates here, my apologies.
From a new owner's perspective, just beware as these cars are very maintenance intensive. However, you'd probably be fine buying one that hasn't received proper maintenance, if it only has 102,000 miles on it.
The issues of a car of that age (which is fairly 'young' in SHO terms - lots of our cars have turned over 200-300,000 miles) are going to be these: the water pump, the CPS (crank position sensor). The water pump leaks with age, and when it begins to leak, it shorts out the CPS. When you're in there to replace the water pump, it would be prudent to also replace the serpentine belt, and the timing belt.
Possibly the rear and front main seals. SHOs leak oil. As long as its not bothersome, you can ignore oil leaks - however, the plug well seals will need to be taken care of in order to insure proper performance and driving. At that age and milage, if they have never been done before, I would expect that they'd be shot.
As the car gets older, the timing belt will need to be done. Timing belts on SHOs rarely break, and even if they do, there won't be any engine damage. I've seen original timing belts go as long as 150,000 miles, but 100,000 is a good spot to go ahead and replace them at.
Also: Rod bearings. They're cheap to take care of preventatively. They're expensive to take care of after they break. At 100k miles, you're probably OK to defer this item for a year or two depending on how often the car is driven and how much. If it were my car and my money, I'd take care of it before 120,000 miles.
Common electrical issues: Well, not too common, but sometimes the DIS module on SHOs ends up going bad. Cheap fix, just find one at a junkyard. Another issue that's fairly common is the multifunction stalk. That stalk controls the high beams, wipers, and turn signals. It very often goes bad around the milage you have. Cheap fix - find one at a junkyard. There are also aftermarket replacements that work fine. For what it's worth, I'm still on my original at 202k miles on my SHO. Alternators on these cars are also a weak point, but they're cheap enough that they're probably a basic wear item. Alternator issues may manifest themselves many ways, but very often will emulate a flat battery, or things such as the A/C not working, or so on and so forth. If the car starts playing up electrical faults, the alternator would be the first place I'd look. Power window switches are also prone to failure, but again, given the low milage of that particular car, I wouldn't think of it as an issue - yet.
Clutches are a weak point, but as long as you're not driving it hard, it should last a good long while. If the clutch in that current car is strong, then ignore this. Just don't be doing constant burnouts or race launches - that's a sure way to **** a stock clutch quickly.
So that's about it. I'm sure I'm leaving off some obscure issues here and there... but I hope this helps.
For what it's worth, we're not trying to scare you off. Just think of a SHO as a car with similar maintenance requirements to a 1980s BMW. They're definitely intensive, and do need a lot of care - but they are also very rewarding cars to drive and own. You need to determine whether or not you/your girlfriend can handle it.
bubba
ATX Connoisseur
Fort Wayne, Indiana
I think the car and motor is good. It's just the owner before you. Taking care of the stuff they didn't do. I've had pretty good luck with mine. If you can make it past that, you will be in good shape.:thumb:
HootUSMC
oh, that guy
Boston, MA
It takes up too much driveway/garage space, on the plus side if you keep washing it they look great. (see signature photo. Notice oil/tranny fluid stain).
Don't get me wrong, if I had the money and didn't have a wife, I'd buy another tomorrow.
gas it
yellow submarine
Check your PM's. Rather than write a book you can call me.
Phoenix
SHOHOLIC
QC , Canada
I thought SHO perf parts were expensive , until I opened up a MM&FF magazine. Mustang performance parts are even worst.
