duplicate key for 96 SHO
Boots Langley
california
Hi SHO Folks,
Questions please.
1) Is there any alternative to the $100 bill the dealer (Drew Ford, La Mesa, Ca.) wants for a spare key to my 96 SHO?
Seems a bit high.:grrr:
2) Does anyone know a competent "V8 SHO" mechanic (Dealer or otherwise), here in the San Diego area?
There are a number of small maintanence items I'd really like to clear up on my car, But just don't want to take the car to the local dealer mechanic who (in this instance); Had a V6, and isn't "afraid" to work on a V8.
Of course, if it gives him trouble he says, he'll just have to charge me.
I'm Sure!
On the job training isn't something I like to pay for! :mad:
So, any help will be greatly appreciated.
Cheers
Boots Langley
1-619-466-7298
Exitwound
_McLovin_
Wisconsin
Just buy a key from ebay and program it yourself. I did it and it was much easier that you may think. As for the other maintenance problems sorry I can't help you there.
Mr Anonymous
Tire Wall
St. Louis, MO
Correct.
For '96 and '97 SHO's, as long as you have one working key you can program additional keys pretty easily (as long as you haven't had the maximum number of keys (8 IIRC) programmed, then you'll still need to go to the dealer). As a matter of fact, even without a working PATS key it's not impossible to program keys.
For '98 and '99 SHO's, if you only have one key the dealer or someone with an NGS is the only way to do it.
Boots Langley
california
96 SHO key
Hi V8 SHO Folks,
thanks for the reply. I'll watch for a key on eBay.
From the sounds of it, they are all the same (all have the same "Cut")?
Once I get one, I'm lost as far as programming it goes. Can someone please outline the steps required to do so?
Thanks in advance.
Cheers
Boots Langley
midnightauto
THE CHOP SHOP
Michigan
brake the chip out of your key pull the plastic column cover off the steering column tape the chip to the xcvr. buy 2 regular keys for $5
Boots Langley
california
Excellant Low $ Tip
Hey thanks guys.
Exitwound, you're a champ!!!!.
Midnightauto. That is an incredibly smart tip!!!!
Cheers
Boots Langley
PS to exitwound; you're my kind of guy (no "fruitiness" intended). I roadraced Kawasaki MACH III 500 and H2 750 2 Stroke Triples during the late 70's and early 80's, here in Southern California.
When it comes to performance, it's good to see Brilliant Minds think alike! ;-)
