I know what that shaving is!
It's part of the block. When the block was originally machined, the main oil galleys had to be drilled. As the drill comes back out, it drops all of the shavings. Well...the bit is still spinning when it's coming out so whatever is on the bit will get flung.
My guess is that the spiral got jammed in the hole and did not come out when the block was washed. Many miles later and lots of oil later, the spiral got "unjammed" and fell into the oil pan for you to find.
. I'm thinking that it's just the oil pan heating up and getting any of the acetone residue off of the outside. The engine sounds great, much smoother.
