Turbo oiling options...
nik97
Mile high
So, from what I gather, the oil pressure sender is 1/2 NPT. Typically a Garrett T3 or T4 has a 1/8 NPT oil supply fitting. My particular Garrett has a the same pitch as the sending unit(1/2" NPT). My problem is that I can only find 1/8 or -4 AN oil supply lines, tees and adapters(NPT-AN). I can find a reducer and go from 1/2 NPT-3/8 NPT-1/4 NPT-1/8 NPT but that would get pricey and cluster-ey. So, what have some of you other guys done(aside from remote filter)? Should I just go to Home Depot?:wave:
Off Road SHO
Moderator
What you talkin about boy? The oil sending unit is 1/8" NPT also. Just "T" it and run a -4 line to the turbo. A -8 or -10 drain back to above the oil level in the pan and your good to go. Come on over and check out The Other Woman's turbo oil feed. It's simple.
Tom
Power Surge
Palm Coast, FL
I'm guessing you're just not familiar with pipe thread sizes. They are not the listed size in inches. A 1/2NPT fitting is almost 13/16". The oil sender and most turbo inlets are 1/8NPT (as Tom stated). An 1/8NPT fitting is about 1/2" or so in diameter.
nik97
Mile high
Tom
Here's what 1/8 looks like according to atpturbo.com. Note the thread diameter in reference to the holes for the m8 x 1.25 bolts.
http://www.atpturbo.com/Merchant2/m...oduct_Code=ATP-FLA-008&Category_Code=ATP-OIL2
Heres my turbo. Note the thread diameter next to the tapped m8 x 1.25 holes.
This thread diameter/pitch is the same as my sending unit(approx 1/2" in center of taper). I'm only assuming the fractional designations for NPT is thread OD.
010
My oil supply hole seems about twice as big. I don't know, I guess I'll have to come over soon. I've already ordered the supply and drain lines(1/8/-4 supply and 1/2/-10). I'll call ya tomorrow;).
BTW, here are some more pics...
001 1
002 3
003 2
005 2
007 2
008 2
:thumb:
nik97
Mile high
Cool, that's what I need to know! Thanks guys.:oops:
DVJ38
Hartford, CT and Worc, MA
Pfff, you didn't understand AN vs NPT? Jeezzzz. :snicker: ;) :shrug:
Lookin good man. Sick welding job. You better have it done by whenever I get down there next! You've given me rides in a V8 N2O SHO, V6 N20 SHO, and now I want one in a V6 TURBO SHO! :dribble: :thumb:
Can't wait for more pics.
