possible to ID a clutch by simply looking?
SuperHO
Mental Patient
St. Joe, MI
All I can say is that it's blue, it's a Valeo pressure plate, and the disc itself appears to have double springs in it...two are shorter than the other two. I'll see what I can do about getting pics up.
Guesses, anyone?
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
I can tell you:
1. whatever it is, has less than 40k on it
2. it came out of a CM box
The previous owner of this car was meticulous in all aspects, but he neglected to tell me what clutch was on that box.
shopartsnw
SHO Medic
Battle Ground, WA
Blue is typically SPEC
A picture shoudl tell.
As far as I can remember, Clutchmasters is not blue (but it may have just been put in that box).
If it is an organic stock looking disk it is a stage 1. If it looks like a felt (kevlar) disk with sections removed, it is a stage 2, if it has six small copper looking pucks on the disk, it is stage 3.
A pic will confirm, but this is my guess.
Mike
SuperHO
Mental Patient
St. Joe, MI
Yeah....it's a solid disc. I've got a stage II in the car right now, so I remember what that disc looked like.
IIRC, clutchmasters are white, ain't they? i know my stage I was when I got it. I can't find any Spec badging or stickers on it anywhere, though....what would I look for?
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
FWIW, I just found a reciept for a SS High revs JR clutch kit, but I believe that the CM1 was the high revs jr (correct me if I'm wrong please)
SuperHO
Mental Patient
St. Joe, MI
you're right...but like I said, I thought CM clutch's were white...and ain't the hi-revs Jr. an older version of the stage I? Perhaps a gooder version?
SASHO91
Zoom Zoom
San Antonio,TX
Sho Shop Hi Rev Jr kit had a blue PP. 100% sure.
CM are white, but I don't think SS went through CM.
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
Well, like I posted above, from what I've heard SS used a HD (bigger strap) PP with a stock valeo disc. I'm 60% sure what I sent you is a SS High revs JR. I have the reciept for it, and if they did not use CM, then it is a High revs JR.
James
yamahaSHO
E85 whore
Arkansas
My SHO Shop Hi Revs Jr/CM stage I was blue. I believe that they use the stock disc.
gmorrell
Never been a noob...
Colorado Springs, CO
James
Those are SS's wider straps and larger head rivets. Some years back, I'd rebuilt a few SS clutch covers, so I have good memories of drilling out those rivets. The shanks are oversized compared to the original Valeo rivets, so I had to Helicoil the holes to use bolted straps.
LOUDSHO92
Rancho Cucamonga, CA
Clutch Masters made the SHOShop clutches, I belive it was the owner there told me when I stopped by to get a clutch.
