ICEMAN007
Hey guys, it's been a while since I've posted. But I have a problem that I can't quite figure out and with minimal information, you guys might not be able to help. I just thought maybe someone has had this exact problem. Me and some of the MNSHO members did some maintenence work on my car and had the intake off, valve covers and the timing cover. After we slapped everything back together, I noticed my engine light comes on now and stays on. I ran the codes and there was an OPEN SPOUT code. Well since there was no physical or noticable signs of any problems, I just basically ignored the engine light. Now, two weeks later, my RPM gauge is going crazy, but not until the car has warmed up and the engine light comes on. When I am driving about 30 mph, you can't really notice anything, but when you get into the 40-45mph range, and you let off the gas after maintaining a steady speed, the RPM guage's needle will drop all the way down to zero and then will sky rocket up to about 5 or 6k and keep doing that sparatically until I step on the gas pedal. The engine is not running those type of RPM's, it's just the gauge going crazy. But there is hesitation when I press back down on the gas pedal when the RPM gauge is acting up. The car will **** just for a second until the rpm gauge maintains the proper revolution point. I'm thinking that there has to be a short somewhere or could a sensor be bad or getting bad? Does anyone have any ideas here????? All your help would be greatly appreciated!!! Thanks so much,
-C
