10psi and a 75 shot should be no problem alex.
15psi and a 100 shot while spraying the FMIC should be no problem alex.
Someone on here did a test and the COPs were not as powerful as the standard setup. It would work fine on a stock SHO but no sufficient on a f/i SHO. I don't remember the COPs used though...
SuperchargedSHOguy said:Someone on here did a test and the COPs were not as powerful as the standard setup. It would work fine on a stock SHO but no sufficient on a f/i SHO. I don't remember the COPs used though...
SHOracer14 said:Corey (1slickred89) used some discarded coils from I believe a 5.4 (possibly newer taurus) with twin DIS. Found the system to be weak because the coils are so small. Do a search for "turbo, igniton fixes" or just pull up all posts by 1slickred89. Basically as he did research finding the COP is not that great and the main reason manufacturers are going to it is because it is cost saving.
Meh, just build up a 3.3 and have it sitting in the garage.
i do 3.3 low comp![]()
ugh ....the attempts at 11 second runs wont be coming as soon as we hoped
the opal frost got pillaged for parts
the parts were received from FPS
the tranny guy assembeled everything
we worked from 8pm thursday till TEN OCLOCK FRIDAY MORNING geting everything assembeled (in an atempt to make it to dunville autodrome @ 4pm)
and as we put the passanger side axle into place we realized theres over a 1/4 inch of slack in all directions betwen the CV shaft and the differential
Called the guy that rebuilt the tranny (localguy) was told its probably fine but if we dont like it we shouldnt run the car
called FPS, talked to doug, explained problem ... he determines that theres a thrust bearing missing and the differential is toast ...and i also think the bearing surface for the cv shaft (in the tranny) is missing, because on the rebuilt tranny that surface is definantly machined aluminium looking ... no gold bearing suface to be seen ...
so now literaly everything has to come back apart
i think this time we will just do it ourselves
nope fastest was 12.92
you can do it sal!!
wouldnt be the first time a big fwd car busted 11's
****, you can hit that # all motor
it all depends on your setup
10's is whats really going to be worth it
all motor 11's my A55
I dont he was serious, by the way...
