ManySHOs
Does anyone forsee any potential brake cooling issues running a 16" rim over 12.2 rotors on the track (open track, not auto-x or drag race)?
Ian
Ian
Ian, folks did it for years using those discs and slicers. The name Chen rings a bell . . . look in the SHOtimes archives.
PM sent - zak
The 40mm offset with the 10.1" wide Hoosier 245's will rub the strut. You'll have to use a spacer, which will move the tire outward (creating an effective offset of 37mm), which will likely require rolling the fender lip anyway.
If you want a different size/style, you need 5 buyers to get an order started.I personally want a lightweight 16x8 rim in this particular style/offset, and that's why I am trying to start this group buy.
If everything goes well, I'd consider doing another GB for a different style/size in the near future.
I should also mention there have been failure issues with the Rota "Attack" and "Subzero" models so I would recommend staying away from those rims.
Did the load rating get sorted out yet?
SHO, essentially, this group buy is only for a very specific rim specs, for one tire type, that will result in rubbing for most others owners that would never run a Hoosier?
Storm-Chaser said:And are there any plans to buy spares? Has the question be asked whether you can order sets of 5, versus 4?
Nice find.
Do they clear 13" brakes like the team dynamics 16 in wheels did???. Just curious
Actually all you would need would be four buyers and an extra set for spares. That would give you five sets purchased, no?
chknhwk said:Being broke sucks, but it's nice owning a house finally.
If I had the cash right now I'd buy a set, between me and my girlfriend we own four sho's, I'm sure a set of wheels could come in handy!The 40mm offset with the 10.1" wide Hoosier 245's will rub the strut. You'll have to use a spacer, which will move the tire outward (creating an effective offset of 37mm), which will likely require rolling the fender lip anyway.
