which way does the input shaft seal go?
Bizzy
The flat side goes to the case, the open side where the spring is, faces upward toward you.
Bizzy
Do you have the seal installer tool to install it? If not I can tell you an easy way to get it seated perfectly without buying extra tools. :thumb:
yamahaSHO
E85 whore
Arkansas
In addition, anytime you see a spring in a seal like that it always goes to the oil side.
93silverbulletSH0
Glendale AZ
Was AREA 91 right, because that's what I already did- I believe I used the axle nut socket. Or do you have an even better way :naughty:
That is a great piece of info, thanks :thumb:
Bizzy
Nope, a nice big socket whether deep well or not will do the trick. Put the flat side that attaches to the ratchet or extension down on the seal making sure it's equally spaced all around. The socket should be as close to the same diameter of the seal as possible. Then take a small wooden block of wood or other flat object and sit that on the socket so that you get nice even blows across the entire seal (so it goes down straight the first time) until you hear the tone change when striking. The tone changes basically tell you that it's bottomed out on the case. Remove the socket and block and double check visually that the seal is nice and evenly seated.
That's it. :thumb:
Edit: The same method can be used to install an axle seal except you don't need a socket. Just a nice small piece of 2 x 4 will do the trick. With this you don't lay it flat but on end so you get even side to side pressure. Alternate position of the piece of wood on the seal to get the seal installed all the way in the case. Easy as pie.
A piece of PVC pipe also works well with an axle seal as long as the outer diameter is the same as the outer diameter of the seal.
n8rsk8r
Hey Where's my post?
Olathe, Kansas
That's it. :thumb:
your so awesome~! I HEART you!! :bigbattyeyes:
