97SHOgt
I'm trying to replace the power antenna with one I got off ebay. The old one is out, I opened up the motor, took out the broken piece, now my problem is getting the antenna to go all the way down. When I actually got the teeth down to the gears, (which was a pain in itself), it will go down part of the way down and then get stuck. I opened the motor back up to find that it is not coilling around like it should. For some reason, the end is folding over and jambing everything up. I'm pretty sure everything is put in there correctly, just seems like the end is getting caught on something after it goes through the guide plate hole, then just stops. The motor is fine. Just having trouble getting this new antenna to feed into the motor, really getting annoying. Would appreciate it if somebody could offer a solution. Thanks....
we pulled the motor and I E-bayed it for like $15.
