Junkyard_Mad-Scientist
Any of you that have followed my whining about my 2013 Gem Green SHO know that it has a hex on it...or I do... either way, it has been quite the problem child not only for my length of ownership but apparently since the day it rolled off the lot. The service records going back to 2 weeks after initial lease are unreal, the repetitive issues I've had in just the last few months have been testing my patience, saying a lot when you consider the number of shitboxes ive owned, my tolerance for new noises and features that disable themselves, or even safe road operation, is quite high. But, a Ford Taurus with any combination of letters after that is still a Ford Taurus in the eyes of book value, can't get out from under it without a massive loss (and I considered taking that massive loss) for reference its about an 8k loss just to trade it off.
Between a rock and a hard place I decided to see my investment through and took a loan out to pay it off and make all repairs and modifications I have been putting off. The list so far:
-Dash removal to replace Evap core (leaking), heater core, and blend doors
-Firewall pass through hole with grommet for outside and engine bay electrics
-Dedicated accessory fuse box with relay triggered by key-on so all accessories are on a keyed switch (dash cam, gauges, etc) with room to grow
-Dash plastics repair (epoxy, sand, paint)
-Ignition coil wire (melted, broken, glued together with RTV by Ford)
-170 degree thermostat
-Colder plugs
-3 bar map
-GH tune
-Tint removal (ammonia and black bags)
-Re-tint with ceramic
-tape/spray all chrome trim (vinyl didnt hold up to the FL sun)
-touch up paint, cut and buff from where I threw a pair of channel locks at the car
-Transmission mount filled with 3m window weld
-Custom lower transmission mounts
-Engine mount (if needed)
-Full Trans, PTU, RDU service
-3rd cat and resonator removal, replace with resonator/glasspack
Already a laundry list and each one either fixes an on going issue (i.e. tuner turns off the CEL for the cat) or scratches an itch I've had since I bought the car, and if im reinvesting for another 6 years might as well get some goodies. What Im missing is some intake and exhaust parts, The airaid set up is what I wanted to go with but price is ridiculous even used, K/N and others look like theyll work fine but again, price is way up there considering what ive already spent. as for exhaust, catless dps is out for now, I have a friend that runs an exhaust shop that said he would take a look at making me some custom ones that would probably be cheaper than the out of box option but again, this budget is getting smaller. what I have been considering is the axle back mufflers off of a stock GT mustang, something that was designed to be a little louder, has similar tips, and I can cut out of a car for next to nothing. so anyone willing to throw in their 2 cents here is the exhaust question list
-running 2 resonators side by side rather than the dual in dual out is far cheaper and offers similar amount of packing, any reason to think it will negatively effect the tone of the car? I know drone is a toss up
-any reason a v8 mustang muffler wouldnt work other than inlet size? instinct tells me its a dumb question but I thought I'd ask the collaborative brain incase there is something im missing.
-I considered an h-pipe just after the resonators to help with rasp so it would be (up stream cat, resonator, h-pipe, muffler) any one try anything like that? I know X-pipe is better for flow but will increase rasp, Ill omit the cross over all together before I add an X-pipe.
and finally, if anyone has a reasonably priced used CAI they want to get rid of let me know, I had someone say they would ship an aFe to me for $125 but they kind of flaked. until hotpipes are in the budget I want something I can attempt to insulate so Im in the market.
And if anyone happens to have a dead or locked sct x4 let me know, seperate needs.
-Colder plugs
-3 bar map
-GH tune
