Austin2013SHO
Hey guys I installed an oil air separator yesterday and got it mounted and hooked up but I have a question for my experts out there. So when installing this both lines run from each valve cover and I used the orginal connection there with some AN fittings to get it to fit but the two plugs you no longer use, one on intake manifold where PCV hose ran from back cover to this ****** and the other on the air intake right below where u block off the return for you BOV when venting to atmosphere. Both used these special locking clips before on the original hoses but now I need to cap them off and wanted to know did you find a direct fit block off or did most people just do a rubber cover with hose claps similar to VTA BOV set up. Below I have provided some picks for your to see what I mean. I tried to look at @802SHO set up and seems like he found a plate for intake but I can’t tell for the other. Any love would be appreciated brother.
PS: I mounted this to the back side of my air box and the breathers actually sit right under vents I installed in hood. White spacers were painted purple also.
