TheRedBeardedFury
Wondering what everyone monitors and looks for on there tuners when daily driving there shos. Just went through the process of setting up custom pids for the sct bdx. Thanks in advance!
BTW folks, greatest use for old tech you got laying around, some old ipad or old android tablet... turn it into a gauge readout, and get yourself a mount.old android phone
I 100% agree. I had to do that with my 01 excursion for the longest time so I'm already a little familiar with forscan. Lots of great recommendations from every one! Thanks guys!BTW folks, greatest use for old tech you got laying around, some old ipad or old android tablet... turn it into a gauge readout, and get yourself a mount.
With FORScan Lite I monitor tire pressure, battery age, state of charge and battery temp in the BCM.I'll add monitor tire pressure of each tire. You can wait until things dip below 27lbs or if a sensor fails for the car to warn ya, but I like to know before they get below 30lbs. Especially in the Summer to Winter transition timeframes.
Depending on your tire/rim choice this may be more or less of a concern.
Fill them with nitrogen, little more expensive but it’s not affected by temperatureI'll add monitor tire pressure of each tire. You can wait until things dip below 27lbs or if a sensor fails for the car to warn ya, but I like to know before they get below 30lbs. Especially in the Summer to Winter transition timeframes.
Hahaha, I’m satisfied with the 78% nitrogen pumped in for free.Fill them with nitrogen, little more expensive but it’s not affected by temperature
so its not the nitrogen its the water vapor that destroys the tires on the inside. I love the nitrogen discussion. generally with nitrogen service is the lack of water which is the most important. its the oxidation that can cause even more damage inside, and why 100% dry nitrogen is better. the misunderstood part is that oxygen and water cause oxidation of the rubber compounds, but by that time you will be buying new tires lol.Hahaha, I’m satisfied with the 78% nitrogen pumped in for free.
