Zero Wastegate and P0299
DDLopes
Massachusetts
So today I set out to datalog the car as Brad sent me another tune. During the datalog I notice the car felt slower than normal. Once I got home I reviewed the log and noticed the car initially made the desired amount of boost for approximately 7 seconds then my waste percentage dropped to zero while the throttle was still at 82%. And the car was only make approximately 5 to 6 psi of boost. I then checked all the boost lines and they all appeared to be tight and without and damaged areas. I checked for codes and came up with P0299. After double checking all the lines again I attempted to apply some air pressure to the system to see if I could hear a boost leak anywhere. Unfortunately I wasn’t even able to build 1 psi in to the system using my homemade boost leak tester. It worked awesome with the Airaid CAI but this EPP CAI is different. Maybe that’s why I can’t. Anyways and assistance would be greatly appreciated. Thanks as always for looking
Maybe the wastegate solenoid has failed?
Where is that located
Couple of posts down. It is on the top of the motor.
DDLopes
Massachusetts
Ok I pulled off the boost solenoid and applied power to it and I could hear it click each time. I'm assuming that means it's opening and working properly. I then applied compressed air from the boost solenoid line to the waste gates and I could hear click. I'm assuming that noise was the wastegate opening. Today I'm gonna apply compress air again and see if I notice the wastegate arm actually moving as air is applied. Nothing is ever easy LOL hopefully its a simple fix and doesn't require $$$$$$.
DDLopes
Massachusetts
Just applied compressed air to the line for the wastegates and I was able to see both arms moving so I'm assuming that means the wastegates are functioning properly. Anyone have some advised to why I only have spring pressure (7psi) and no boost? Thanks for looking.
DDLopes
Massachusetts
Ok so I may have found the issue. But I gotta wait for another set of hands. With both pipes leading to the EPP CAI capped I applied air pressure to the test line I installed for my boost activated x-pipe cutout. As I applied the air and covered the Mac valve bleeder I could hear a large amount off air leaking out at the back of the engine. Once I get a second set of hands to apply the air and cover the Mac valve bleeder I can go under the car and see where the leak is coming from. I hope it’s not the rear turbo hose!!! That will be a bitch to tighten !!!!
Nice. Hopefully it is easy, even though it will probably be a complete bitch.
DDLopes
Massachusetts
Well for once I got lucky!!! The boost line going to the boost activated cutout was torn. Looks like it was torn from being up against a support bracket. I'll have to reroute the line. Thanks again!!!!
Nice. It is always cool when it is easy.
