DDLopes
So today I set out to datalog the car as Brad sent me another tune. During the datalog I notice the car felt slower than normal. Once I got home I reviewed the log and noticed the car initially made the desired amount of boost for approximately 7 seconds then my waste percentage dropped to zero while the throttle was still at 82%. And the car was only make approximately 5 to 6 psi of boost. I then checked all the boost lines and they all appeared to be tight and without and damaged areas. I checked for codes and came up with P0299. After double checking all the lines again I attempted to apply some air pressure to the system to see if I could hear a boost leak anywhere. Unfortunately I wasn’t even able to build 1 psi in to the system using my homemade boost leak tester. It worked awesome with the Airaid CAI but this EPP CAI is different. Maybe that’s why I can’t. Anyways and assistance would be greatly appreciated. Thanks as always for looking
