Tranny job coming up soon. CM, Spec or South Bend
Devin
3.Slow
Pacific Northwest
Stock '90 SHO. Don't really look to be adding power now, or possibly ever. I have a CM stage 1 clutch I got way back when Midwest SHO was around, and I am looking to pull it down on a friend's rack and do some maintenance. Haven't really paid much attention lately, but should I stick with the CM or go Spec or South Bend? I know nothing about the latter two, or if CM is still quality.
zoomlater
Seattle, WA
I read some have had issues with South bend, you can probably find the post on this forum pretty easily. Haven't used them yet, but I have a stage 1 that I have been holding off installing because of those posts
Irish Pride
Irish Inside
MusicCityUSA
Oreillys/Sachs stock clutch from O'Reillys. Lifetime warranty! I have this clutch in every one of my SHOs except the boosted one. Even have the O'Reillys clutch in my Moonlight 3.4
-Chad
Devin
3.Slow
Pacific Northwest
Stocker, eh? Not what I expected to hear!
Next question... any purpose in changing out to a lighter (17lb) flywheel?
Irish Pride
Irish Inside
MusicCityUSA
Stock clutch will handle anything you can throw at a naturally aspirated SHO and has the best pedal feel. The lifetime warranty is worth it too.
I also have the SHOSource 17lbs flywheel in several of my cars. It's the best option for a lightened flywheel. I've used them all, 8lbs, 9lbs 12lbs, and I've sold off all of them once clutch time came around. For me it's the 17lb one or stock.
-Chad
Devin
3.Slow
Pacific Northwest
-Chad
I can't find a stock clutch on O'Reilly's website.
black92
Wisconsin
If you choose Spec, Inspect it very closely.
This was purchased Nov 2023. I reached out to SPEC and was assured this is not an issue. Do not let Spec mislead you. These bent straps are indeed an issue and should not be acceptable. I returned my Spec product (another issue) and purchased a Clutch Masters from SHONUT.
Irish Pride
Irish Inside
MusicCityUSA
The O'Reillys clutch kit and the Sachs kit on RA are the exact same kit. It's cheaper from O'Reillys and you get the lifetime warranty.
-Chad
Screenshot 20240214 074713 Chrome
Screenshot 20240214 074612 Chrome
Irish Pride
Irish Inside
MusicCityUSA
I used a Spec clutch kit one time and I didn't even get 10k miles out of it. I'll never use another one.
-Chad
Devin
3.Slow
Pacific Northwest
@Irish Pride That's terrible. I think I'm up to about 70K on my CM stage 1. Thanks for the link. I put my car in and searched for clutch kit and it came back with 2000 results.
Deathacus
Pennsylvania
Personally bought all OE equivalent clutch parts from SHOsource a couple years ago, including a resurfaced OEM flywheel. Much smoother than whatever "high performance" stuff the guy before me had but tbh there is a ton of rev hang, so a lighter flywheel might be good unless you're dead set on going stock.
Probably the same thing as O'Reily or something but I didn't mind paying more to support the last specialty shop.
BaySHO Performance
SF South Bay
Either the aforementioned Sachs (80 thou reinforcing straps) or Clutchmasters Stage 1 (120 thou reinforcing straps with HD rivets) for better shock loading. My go to flywheel is the 17 lb.
