Acceleration shudder over 80
shaldaya
Utah
Everything seems mostly fine, but when i floor it, i feel a very slight shudder around and above 80 mph
All I've done so far is change the air filter, and I'm thinking to try the fuel filter next
Can anyone suggest possible causes?
model year, mileage?
if felt in the cabin area under the seats, it could be driveshaft
if at cruise and shudder is experienced it could be torque converter.
what is the transmission fluid maintenance history?
bpd1151
Lurking Around
SHOcago 'Burbs
I had the same experiences with my SHO, prior to its latest engine demise.
Never did get a chance to pin it down, or diagnose it accurately.
From reading a few others, I suspected driveshaft myself. Thus why I ordered a brand new driveshaft in advance of my SHO's return.
Will be interested to see what others come up with as far as suggestions.
Sent from my SM-N986U1 using Tapatalk
Lurch.sho
Orlando
I'm currently having a similar issue, not enough vibration to cause any problems but enough to not ignore it either. For me when I notice it, it has less to do with how fast I'm going and more with how high my engines revving. Would love to learn what this is about, might take it to the dealer to see as well since I still have my warranty, if I do ill post what they say here.
shaldaya
Utah
It Would definitely be highly appreciated if you did post whatever the dealership says
Bluezone
Ont, Canada
Might be a good idea to have the intermediate shaft support bearing checked out. I had a shutter above 70 and it turned out the bearing was going bad. This is the shaft that comes out of the PTU to the right hand CV axle.
Kingsped
I'm experiencing the same exact thing you are describing with my 2013 Flex Ecoboost..
shaldaya
Utah
I tried oxygen sensors and it's better, but still there
shaldaya
Utah
FOUND THE ISSUE
it was a vacuum line that came off, i assume it checked for balance between the two turbo
The line is one of the 3 in the photo on the top left of the engine
