95 ATX starter motor location?
Wyatt_sho
Athens Al
Trying to do a crank sensor and get the harmonic balancer off and I need a away to hold the engine
What does starter motor location have to do with this? Are you trying to bump start the crank pulley bolt?
Wyatt_sho
Athens Al
No just trying to remove that starter to use the teeth of the flex plate to hold the engine while I remove the crank pulley bolt. But I ended up finding it’s location regardless.
Irish Pride
Irish Inside
MusicCityUSA
Next time just do a starter bump. No need to hold the flex plate or remove the starter.
Unplug the DIS on the intake so the car cannot start. Then use a breaker bar with a 19mm socket. Put the socket on the bolt and rest the breaker bar on the subframe. You may have to turn the crank some to get a snug fit. At that point get in the car and crank the engine. The torque of the engine trying to start, via the starter, will break the bolt loose.
-Chad
