i ended up finding it. But to hold the engine so I can loosen the crank bolt without it spinning.Hold the engine for what purpose?
-Chad
No just trying to remove that starter to use the teeth of the flex plate to hold the engine while I remove the crank pulley bolt. But I ended up finding it’s location regardless.What does starter motor location have to do with this? Are you trying to bump start the crank pulley bolt?
