InTheHills
This is my plan for the new to me 2015 Lincoln MKS EcoBoost AWD with 81k miles. I purchased this car after it ran over a dead deer, the Ford Body Shop had her 95% of the way to fixed when the insurance company decided to ‘total’ the car. I got a pretty good deal on her at auction and my plan is to finish the bit of remaining work, use as my daily driver and improve as I go. I am putting this here for review and suggestions as well as to track my progress!
Already done:
4 Wheel Alignment & Rotate Tires
Oil Change - Synthetic (used Wix Filter out of necessity)
Coolant was new with the new Radiator
Ford Dealer Appointment:
Crash Warning - On Startup
Adaptive Cruise Control - No Cruise Control At All
BG - Power Flush of Trans - TPU - RDU - Hopefully fill with Amsoil or Redline
Inspect Around Water Pump For Any Leaks
Seat air filter FS-104 & Cabin air filter FP68 - I cant find them anywhere
This Week:
Install K&N Drop In Air Filter
Clean Battery & Terminals
Titan (USA) Wiper Blades
Deep Clean & Detail
Add Weather Tech Floor Mats
Paint Correction
Ceramic
Next Week:
Install UPR Catch Can
GearHead Motorcraft CX2594 3BAR MAP, Motorcraft plugs at 0.028, & 170 degree thermostat
GerHead AO Tune - SCT x4
Log for GH to Review Engine Health
Anthony Trans Mounts
And then…
My plan is to enjoy the car as I improve cooling all the way through. I will stick to this order unless someone sees a fatal flaw, parts are simply not available or something breaks.
Step 1 - I think the GH Intercooler and EPP Hot Pipes should be high on the list and easier to install together.
Step 2 - I'm planning to throw all of the PP cooling at this via Schwartz Packages for the Trans, Oil Cooler and PTU (with drain installed)
Step 3 - PPE Catted Up Pipes as well as 3rd Cat & Resonator Delete. For now I am thinking about a H-Pipe, MagnaFlow Resonator and MRT Mufflers. I hate buzzy import sounds and drone so this will require much more research.
Step 4 - Phenolic Spacers & Meth Injection. I am most interested in Meth for the cooling and cleaning properties. However, I have exactly ONE e85 station within 80+ miles of my house and even that is 20 miles away. I understand the e30 would be amazing but I dont see how it would ever work for a daily driver in the Ozarks. So I may explore using a 50/50 Direct Port Injection Meth system such as Pro-Meth or Aquamist for power, cooling and cleaning.
As Needed -
When I need to do tires I will be going with the lightest decent looking 20x9 (or 9.5) +35 wheels I can find. Currently American Racing AR-924 in Gray are winning but I really don't think they will match this silvery tan (Luxe Metallic) MKS. I am VERY open to suggestions here. The wheels will be wrapped in Continental DSW06 Plus -275/40/20 tires (don't tell my sister who is an engineer at Michelin LOL)
When it's time for brakes I will be doing the Schwartz Wilwood 4 Piston Super-Light Upgrade and Whiteline Rear Bar at the same time.
If the Turbos go then Ill be doing GH Turbos with the EPP Dual Intake.
Now one big question… is there EVER a case to be made for doing the Water Pump & Timing Chain preemptively?
Im not scared of the truth so hit me with it!
Gypsy
Already done:
This Week:
Deep Clean & Detail
Paint Correction
Ceramic
Next Week:
And then…
As Needed -
Gypsy
