Actually your labor rates for local shops (not your personal rates) isn't that far off from what they charge around here. Maybe a little more, but not by very much depending on the shop
| Intake R&R | 2.0 hours | 160 | Needed to get at hoses 7 & 8 |
| Intake Manifold Gasket (2 Felpro) | MS94831 | $18 | Rock Auto |
I would try emailing them again, but I am pretty sure its the correct one. Maybe there is just some residual oil that still needed to be burned up. Looks like Sparks has a lot of those throttle bodies so maybe you can continue to see if your car gets better over time.Thanks for the pointer on those TBs with and without the TPS zoomlater. I guess its just an oversight, but the TB without the TPS does not have a year. It looks like mine. I've not had much luck emailing Sparks, the vendor. Do you think this is the right TB for my 89' SHO zoomlater. I'm thinking that the TB was the same for the 89-95 SHOs based on the ad with the TPS.
And I'm thinking that the 2nd NoSlo picture (EGR passages/intake interface to TB) was as far into the manifold as I would go. The EGR passages surface could be cleaned. But no telling what the other side of the intake into inside of the manifold looks like - months of high oil use and periodic smoke ups.
But the car sure is running good, and sometimes it does not smoke up or its just a small amout or just the smell.
I took a look at the two spare throttle bodies I have and they are both marked KOA-02. You should be able to look at your car and see what part number is on the throttle body. The number is on the top side so you should be able to see it with it installed. I don't know the difference between the two, but I would have thought they were interchangeable. Perhaps someone else can chime in if they know what the difference is between the -02 and -03.zoomlater, Sparks got back to me and said that the only casting number stamped on the throttle body is KOA-03. This is a 65mm throttle body for the 3.0L MTX (1992-1995) he said. I still don't know if this will fit my car. I hope they have one for my car.
