Tires for 2016 SHO
KevsAzSHO
Tucson, Az
Howdy, my 2016 SHO came with Pirelli p zero tires. Needless to say, without even really working the car hard, I went through those tires in 27k. I believe the 2019's came with Goodyear tires?? If so, can anyone give me the model and specs on those tires and how they perform? I'm at 61k now and getting close to needing tires again. Any help would be appreciated. Kevin
Majestic
Might have better luck posting this in the proper section. I've had good luck with BF Goodrich G-Force Comp 2s, though they are a little louder than I like.
I am a fan of the Continental DWS 06 Extreme Contact. They are a great all weather tire.
KevsAzSHO
Tucson, Az
I looked at all the section options, must have missed it :)
Bluezone
Ont, Canada
I'm running Continental extremecontact dws06 Plus. The new version of the dwso6. Handles and feels even better can the old model.
76FoMoCo
Nampa, ID
rememeber your driving a 4500 lb boat with the driver and AWD. these things are a bit more consuming of the rubber when you push it. So I do summer and winter tires as I daily mine all year long.
KevsAzSHO
Tucson, Az
Luckily, or maybe not, in Arizona we only need one set of tires. My days of living back East are long gone. :)
I live in AZ and the Conti Extreme Contacts are the tire I prefer. We still get rain, dusty roads, hot and cold roads, ect.
MNRubyRed2013
I'm running Firestone Firehawk Indy 500's on my 2013, as summer tires (need snows here in Minnesnowta). I really like them and there are a number of 2010+ owners that run these.
SilvererSHO
50 miles north of Minneapolis, Minnesoder.
Is anyone running a 265/50-20? Curious on fitment with stock wheels.
I don't think you're going to have room up front. I run one size over stock on stock wheels (255/45-20) and these tire would be almost 1 1/2 inches taller than mine. I think anything over 1/2" - 3/4" taller than mine is going to rub up front from looking at mine when the wheels are turned. 265/45-20's would probably work but you're getting a little wide for the stock wheel.
SHOthyme
MN
If you are looking to go wider, I've noticed people going to 275/40r20's without spacers, as long as you get the offset right.
As a matter of fact, once I go through these, I will probably end up with some DSW06's in that size.
KevsAzSHO
Tucson, Az
Howdy, my 2016 SHO came with Pirelli p zero tires. Needless to say, without even really working the car hard, I went through those tires in 27k. I believe the 2019's came with Goodyear tires?? If so, can anyone give me the model and specs on those tires and how they perform, or what tires you are using? I only use one set year round since I'm in Arizona. So, looking for a good performance tire that matches the car's ability. I'm at 61k now and getting close to needing tires again. Any help would be appreciated. Thanks, Kevin
Majestic
I think you received quite a bit of feedback in your original thread, no?
