Valve cover bolts
No. at this age look for rust issues at the subframe, fluids, suspension, and hope the crank sensor holds up. Also check the sparkplug tubes for oil. Same ish mtx and atx car issues. Also a/c is potentially expensive to repair if you want to haggle it down a little if it's not cold
Samtheman94
Grand Rapids, MI
Good to know, thank you
Irish Pride
Irish Inside
MusicCityUSA
In the Ford parts catalog it specifies to "improvise from bulk tubing". I dont see any option other than finding some lines off a clean donor.
-Chad
I think that is why the fittings are listed along with bulk hose as replacement items from the chain parts stores websites
